cam change low vacuum
Old Jun 25, 2010 | 09:48 AM
DEM3500's Avatar
hey guys. new to third gen and to tbi.
my dad has a howell tbi setup in his jeep and recently installed a new sbc 350. apparently the cam has too much overlap and is causing the vacuum to drop to about 13psi at idle. i know that this is affecting the map. it will stumble and stall while in park. is there something in the .bin i can change to over come this problem? the computer is the 7747 and 42.xdf. the system does not use the distributor control or vss. i am also in the process of installing tbi on my jeep and am expecting to have the same problem.
thanks
Old Jun 25, 2010 | 10:15 AM
dan0617's Avatar
Re: cam change low vacuum
Getting the idle rpms higher should help. It likely needs some timing and fueling adjustments, usually needs quite a bit more timing when idling with a larger cam. I see you said you don't have distributor control. Try physically turning the timing up about 8 or so degrees just to see if that helps at idle. I wouldn't suggest going WOT with it turned up, just do it to see if it helps the idle and part throttle.
Old Jun 28, 2010 | 10:35 AM
Ronny's Avatar
You need to locate a datalogging cable and complete a log of engine operation. You can use winALDL or Tunerpro RT. As you state first step is to address fueling at idle (and off idle under load). Logs to be done with steady throttle on level road to start.
You may want to look at a SA table for a GM 1/2 ton pickup with auto trans using its curve. Keep in mind there may be "adders" for WOT in that .bin. that .bin is located at craigmoats under downloads. It can be opened with TunerPro.
Old Jun 28, 2010 | 12:28 PM
DEM3500's Avatar
ok. thanks. im currently working with moates to get all the hardware needed to complete the task.
Old Jun 29, 2010 | 11:12 AM
DEM3500's Avatar
ok i just ordered the apu1 and a few chips
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 19, 2015 01:36 PM
cstrobel65
Aug 15, 2015 10:19 AM
