breaking up after 3.5K rpms (did a search too)
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
before i get flamed lol, i did a search and i only found threads the seem to dead end. even searched on google
specs;
3.4 60*v6
ported irons
crane solid cam(250801)
howards solid lifters
ported heads
roller tip 1.6 rockers
115# closed 340# open valve springs
7747 ecm with 4.3 APAB 5spd bin
4.3/5.7 tbi with 55# injectors
walbro 255lph fp
adjustable fpr at 15 psi
calculated BPC to 94
now the problem. im fresh in tuning so im learning lol. i just got the truck on the road the other day and started dialing in the BLMs, everything looks good around 128. then i started taking the rpms up little by little, eventually got the rpms up to 3500 to 4K and it lost all power and started breaking up real bad, popping out the exhaust and intake. i tried backing off a little timing and adding fuel to the VE adder table. no change. the O2 says its lean but im not sure if its lying to me since the engine is breaking up so bad. engine is brand new, everything is brand new. im not sure if im missing a setting somewhere thats fighting me every step of the way. even read bruce plecan's tuning tips stuff and BMonte's thread too. i set the WOT tps enable to 80% so i can get the blms dialed in the 70-90 kpa range. when i try to punch it, it breaks up alot sooner, like 3200-3400 rpms. i even bumped the fuel pressure up just to see if that would help, same end result. so can somebody tell me what im missing? id really appreciate the help. thanks!!!
specs;
3.4 60*v6
ported irons
ported heads
walbro 255lph fp
Engine: LZ9????
Transmission: 2004R
Re: breaking up after 3.5K rpms (did a search too)
yep that was it, good call RBob. dropped off to damn near zero as soon as it hit 3500. will grap another pump ASAP. thanks!
Car: check
Engine: check
Transmission: check
And, a BTW, I've never known a 255 LPH pump to be able to be lowered to 15 psi on a TBI setup. There is just too much fuel to be bypassed.
This drives the pressure up.
Better off on a mild TBI to use a GM TPI pump, or maybe a 190 LPH pump.
The reason is that at lower pressure a pump flows a lot more fuel. Which can't all be returned to the tank.
RBob.
Engine: LZ9????
Transmission: 2004R
OK, but it is better to check out the pump/feed in the tank first. It is very possible that the hose between the pump and outlet tube is split.
RBob.
RBob.
Engine: LZ9????
Transmission: 2004R
welp, im an idiot
the fuel filter was clogged, replaced it and it runs alot better. thanks for the replies!
the fuel filter was clogged, replaced it and it runs alot better. thanks for the replies! Thread
