Turn off shift light
Old Jul 21, 2010 | 01:38 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
I have an automatic and I'm trying to turn off this shift light.
In the constants
Shift Light Output- I raised all the way up
Shift Light RPM (8 cyl) , I've raised to 9999 RPM
Under option words
Option word 3 bit 4, I've even checked and unchecked
the darn thing still doesn't turn off, stays on all the time. Is there another area to turn this off?
thanks
Old Jul 21, 2010 | 04:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Turn off shift light
Are you sure that the shift light is controlled by the ECM? The reason I ask is that looking at an '84 Y body ECM pin out ('6026), none are for a shift light.
RBob.
Old Jul 21, 2010 | 04:56 PM
Stephen's Avatar
Car: 87 GTA
Pull the bulb out. If there is a bulb in there, in an automatic trans car, it will come on & stay on (I know because I tried this). Just pull the bulb. Pretty simple.
Old Jul 21, 2010 | 07:26 PM
slrvette's Avatar
Car: Corvette
Not in a digital dash its not that simple. (corvette)
Well I don't know for sure how its wired into the ecm or if that controls it. The only thing I can go off of is that when the car was a TBI and I first put ebl in the light was on. Went into the program and was able to turn it off. Went to muultiport and All of a sudden its shown up again and won't go off. May have to live with it.
Old Jul 22, 2010 | 11:45 AM
slrvette's Avatar
Car: Corvette
Well, I've literally gone through every LCD dash schmatic from years 84 to 86 and now where's can I find a wire that supplies a signal to the shift light. So looks like I better get used to it.
Old Jul 22, 2010 | 11:53 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you feel like emailing/PM me a link to the diagrams (or the diagrams themselves), I'll take a look at it.
Lou
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
