Inaccurate Datalog, this is weird
Old Aug 8, 2010 | 06:50 PM
caboboy's Avatar
Car: '87 Corvette Convertible
Engine: 421 CID, Superram, LPE219, AFR 195s
Transmission: Built A4
Axle/Gears: D44 w/ 3.07s
What might cause an inaccurate report on my datalog? I'm tuning an ARAP based 6e, and every so often I'll notice something obviously out of whack. Sometimes the desired idle will report wrong, sometimes it's something else. The example below is a snapshot of a reported 43.24 advance (column H) when in reality my actual table isn't anywhere close.........see attached.
The columns are (in order): Veh speed, RPM, TPS, BLM Cell, BLM, INT, LV8, Timing, MAF
I'm totally lost on this........... could there be an address problem of some sort?
Attached Thumbnails Inaccurate Datalog, this is weird-timing-issue.jpg   Inaccurate Datalog, this is weird-timing-issue-advance.jpg
Old Aug 10, 2010 | 10:36 AM
caboboy's Avatar
Re: Inaccurate Datalog, this is weird
Does anybody have any ideas on this issue? The crazy thing is the very same datalog shows a correct timing pattern in the same light cruise area later on in the report. See below for a comparison, I'm totally lost.
Old Aug 10, 2010 | 12:33 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
what was the coolant temp at the time when it was reporting 43.24?
Old Aug 10, 2010 | 01:07 PM
caboboy's Avatar
Hummm, good thought. I'll check it when I get back home tonight & repost. Thanks!
Old Aug 11, 2010 | 09:47 PM
caboboy's Avatar
i just checked my datalogs, the temp was a rock solid 192.2 the whole time.
Old Aug 11, 2010 | 09:56 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
something must have been causing the PCM to command more advance... TP can't log "inaccurately" like that, it only reads the stream and converts hex values into real-world values.... so the PCM was commanding more advance, the mystery here is what was causing it. look around at any other values, see what's different other than advance in the same conditions.
Old Aug 13, 2010 | 11:34 AM
caboboy's Avatar
I had a chance to look at that D/L again & I can't find any conflicting values in those examples except for the timing entries. In previous D/L's I've also noticed an occasional misreporting of timing similar to this one. In the past, I've also noticed that my desired idle report will vary sometimes between 700 and 800 RPMs from datalog to datalog.
Could this be a problem with the ECM?
Old Aug 13, 2010 | 11:47 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
IMO, it's not a misreporting.... it's actual advance, but for some reason it's varying.
without pouring through a log, i wouldn't know for sure, but i highly doubt the advance shown in the datastream and the actual advance commanded are different.
Old Aug 13, 2010 | 12:09 PM
caboboy's Avatar
OK, thanks! Can you give me any idea what to look for in my logs? The only place I've seen this is with a rich condition of 118. I have some 120 & 124 BLMs but they seem to show correct parameters within the advance table. I looked at knock counts & retard, but there's nothing there either.
Also I'm pretty new to this, is looking thru an excel file like I'm doing the best way to analyze these logs? Thanks a lot for your input!
Old Aug 13, 2010 | 12:14 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
yes, an excel file will allow for some very quick comparison to get an idea of what all is happening...
if you want a second opinion, email the log to me
robertisaar at yahoo .com
Old Aug 13, 2010 | 02:15 PM
caboboy's Avatar
Wow, what a generous offer, many thanks! I'll do that when I get home tonight.......I'll send the current bin along as well. Thanks again,
Tim
Old Aug 13, 2010 | 05:33 PM
tequilaboy's Avatar
Check your highway mode spark advance. It may explain what you are seeing. Coolant compensation is another possibility.
Old Aug 15, 2010 | 08:36 PM
caboboy's Avatar
Mystery Solved!
As tequilaboy suggested in the previous post, and as Saar discovered looking over my log it turned out to be the highway spark triggering add'l advance based on the LV8 plateau. Thanks to Saar for taking the time to help this noob & thanks to tequilaboy for his great suggestion.
You guys are amazing!
F-body-fan
May 4, 2026 09:42 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
86IROC112
Sep 11, 2015 04:04 PM
