305 to 350 + EBL
Old Aug 9, 2010 | 10:52 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
305 to 350 + EBL
I will be starting my 350 swap in the coming months and have some questions about using the EBL with it. Can i use my stock L03 ecm to run my new 350 with ebl since i know it has to be modified or will i need a 350 ecm to start? Once ive gotten my ecm and software taken care of, where can i get a base bin to start with?
Old Aug 9, 2010 | 11:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 305 to 350 + EBL
The stock '8746 ECM will work with the EBL Flash and the 350 engine. You may also purchase an ECM with the EBL Flash already installed. This too is a good way to go.
Included with the EBL are 30-some base calibrations. There are a bunch for the L05 engines. Then a couple for the TPI L98 engines. So depending upon which heads & cam are in the 350 you can go with a L05 calibration. Or, start with one and copy the L98 spark tables into it.
RBob.
Old Aug 9, 2010 | 04:44 PM
Car: 91 GTA
Axle/Gears: stock
thanks. thats exactly what i needed to know.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
