Interesting info...and odd issue, 89 HSR car..
Old Sep 11, 2010 | 09:09 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
ive been having a terrible rich smelling idle..
did a search for a few things, and ran across an issue with 02 mv reading super low at idle...
which mine seem to do.. im getting down as low as 50mv at idle
had read that a few issues were cause of a lean condition...
out of curiosity, i started to raise my FP, and sure enough, i watched my BLM's go down closer to 128ish...this occured at 80psi pressure...
and watched O2 volts hang pretty steady around .475/.500 volts, at idle..
im kinda helpless right now without working burner stuff...ugh!
Old Sep 11, 2010 | 10:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Interesting info...and odd issue, 89 HSR car..
Its funny how lean conditions can make you smell rich conditions.
Old Sep 11, 2010 | 10:31 PM
On Probation
i know right? i read a few threads with the same issue im having...
and was like lean smells rich?! wtf..
Car put down 363@5700/439@4500.. hp/tq..
afr readings are 13.8/14.0 at WOT...
still a **** ton of tuning to get done..ugh! i think im going to give up on this MAF and swap to SD..im getting maxed maf rates at 4600ish RPM now.
Old Sep 12, 2010 | 03:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Can still use PE mode to add fuel above 4600 where maf maxes out. Nothing wrong with that. If you are using a turbo motor then go SD with some sort or 2 or 3 bar map capable setup.
MAF does well in adjusting fuel at part throttle and is less picky than SD. SD requires you to dial in VE for each cell in rpms vs MAP readings. takes more time to get right.
Infested
May 22, 2018 11:56 PM
InfinityShade
Feb 21, 2016 01:29 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
