maf reading jumping ignition on
Old Sep 12, 2010 | 03:40 PM
bdiroc's Avatar
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
hello , fighting idle problem, acts like a vacuum leak but havnt found one, but while troubleshooting I saw with ignition on car off, maf reads 5 on the flow which is correct but It jumps to 2 and up to 27 about every 8 seconds , tryed unhooking maf did the same even jumped to 127. so I hooked up another maf same results. this cant be normal can it? raw readings on maf are rock steady at 62.can someone confirm with tunerpro maf reading and maf raw are both rock solid for me. any help or guidance would be appreciated thanks guys
Old Sep 29, 2010 | 05:44 AM
dek1285's Avatar
Re: maf reading jumping ignition on
i am having the same problem as we speak. mine with start at 5 then jump to 30 and instantly jump back to 5. what kind of idle problem are you having and if someone knows if this is normal please let us know thanks
89GTAOz
May 16, 2020 09:31 AM
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
chazman
Aug 22, 2015 02:01 PM
