7747 Collant Comp Spark & Spark Bias - Cold
Old Sep 20, 2010 | 01:17 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
This is probably an odd ball question as 7747 $42 has been extensively hacked and documented.
My question is regarding Spark Bias - Cold Constant and Coolant Comp Spark table. In the past I always set my Spark Bias - Hot to 0. Then my main SA table reflects uncompensated spark advance actual values. From this value Spark Bias -Cold is subtracted and Coolant comp spark (a two dimensional lookup based on temp and vacuum) is added. There are other modifiers, but they are not relevant to this discussion.
Typical calibrations use Spark Bias - cold = 20.04 which is the base value used in Coolant comp spark at normal operating conditions. What reasonable values can be used Spark Bias - cold i.e. so as long as Coolant comp spark are not negative??? My warm bias is set to 0 and Main SA reflects actual commanded SA.
//RF
Attached Thumbnails 7747 Collant Comp Spark & Spark Bias - Cold-cold-compensation-sa-tables.png
Old Sep 20, 2010 | 07:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7747 Collant Comp Spark & Spark Bias - Cold
I prefer to use 10* for the cold bias. This makes it easy to mentally subtract from the compensation table values. And it is rare that more then a -10* SA value is required.
Although, if you have no values in the compensation table that is lower then the bias, then a bias of 0 can be used.
RBob.
MM2Robinson
Oct 1, 2017 09:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Jorlain
Oct 8, 2015 01:57 AM
camarohelp
Sep 22, 2015 03:19 PM
Jlanz55
Sep 9, 2015 09:09 AM
