Please help me decide
Old Oct 4, 2010 | 03:39 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I am finally getting ready to start tuning and am in the process of buying hardware. Right now im thinking about the ostrich and the moates aldl cable. If I only plan on messing with my one car is there a reason i should go the autoprom route. I heard someone say something about how with the ostrich and seperate aldl you could use different programs to datalog I assume that would be a good thing. this is my first time and ill be doing on a 165 but plan to change to 730 later for boost capabilities, so if you have any suggestion let me know.
Old Oct 4, 2010 | 07:56 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Please help me decide
You need to look into the EBL from DynamicEFI, hands down the best.
Old Oct 4, 2010 | 10:16 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
How does the ebl flash have an advantage over an emulator like ostrich. I think the real question I have is do I need to have a "hard copy" or can I trust the ostrich will always work because once I switch ecm's I will no longer have an original prom and will be relying on it.
Old Oct 4, 2010 | 10:47 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I've been running the Ostrich 2.0 in my Datsun (1227749 running $59) for a little over two years now. I haven't experienced any hiccups.
Old Oct 4, 2010 | 10:59 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
alright I guess im sold on it then all I need is the Ostrich 2.0 and a g1 adapter and that will cover everything I need to tune plus an aldl cable to datalog and im set right. Theres no small things I dont know about that I need to buy right.
Old Oct 4, 2010 | 11:16 PM
Yep, sounds right.
The Moates ALDL cable works nice.
I also use Tuner Pro RT for a tuning program.
Old Oct 5, 2010 | 12:01 AM
xch3no2's Avatar
Transmission: TH400
I won't argue with success, & the Moats gear has the advantage of being able to use your own, or others, custom definition files and transportability from one rig to another.
I feel that the EBL has the advantage in ease of use, the WUD, tune on the fly and of course VE learn capability & user defined add-on's.
I also use TunerproRT (v4) for editing.
Old Oct 5, 2010 | 01:07 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
well I ordered my ostrich and supporting gear cant wait to get it this may be the only sticker to ever make it on my car. I was somewhat enticed by the ebl but decided to start with stuff thats been around for ever, for when I need help.
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
