305 TPI with TBI heads, need timing suggestions.
Old Apr 22, 2009 | 11:24 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Title says it all, I've built a TPI 305 with stock LT1 cam and TBI heads. I'm sure these heads have different timing requirements than the 081s did, so I'm just looking for suggestions if anyone has done any TBI tuning and knows about what they like timing wise. I may just dump the timing values from a TBI tune in to the stock TPI 5spd .bin and start from there. Thanks guys.
Old Sep 16, 2010 | 05:02 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Re: 305 TPI with TBI heads, need timing suggestions.
did u everfind what timing to set it at i need same thing
Old Sep 16, 2010 | 10:23 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I've got the car tuned pretty well. I can send you my .bin if you like...
Old Sep 17, 2010 | 01:39 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Yes, put the TBI table in as the starting point. (been there done that)
Old Sep 22, 2010 | 07:25 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
thats cool send them to me please
Old Sep 22, 2010 | 07:26 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
what cable did u use and what program did u download to tune it
Old Sep 28, 2010 | 04:20 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I have the moates AUJP1
Old Oct 4, 2010 | 12:40 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
The 081 heads came off of your 86 car? I have an 86 and was wondering what head casting i had.. thnx
Old Oct 4, 2010 | 08:02 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
081s are the 87 and later center bolt TPI 305 heads. 416 castings are basically the same ports but perimeter style bolt pattern. They were used on LB9, L69, and LG4.
Old Oct 4, 2010 | 10:46 PM
I have centerbolt heads, but i have an 86 iroc... they rebuilt the engine before i bought it.. could it be possible there were some 86 irocs with this head? Or are the heads NOT from my original engine?
Old Oct 5, 2010 | 07:06 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
center bolts are not original to an 86 engine, but they are no different than the perimeter style 416 heads as far as the ports are concerned. The only difference is the center bolt valve cover bolts and the angle of the middle 2 intake bolts is at a slightly different angle but you can fix that by drilling the intake out slightly.
If the engine has center bolts on it, you may have a later engine all together. Check the numbers on the bellhousing pad behind the driver's side head and run them on mortec.com You may have a later roller cam block as well.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
