Prominator
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Prominator
Hey I was just wondering if they still make the prominator and if they do where can I get one? I just did the 350 TPI swap in my 91 RS and in need of a tune because of the cam I installed. Any info would be great. Im using the 730 ECM too.
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: Prominator
"MrBill" was the forum member here who made them originally. His website for Speedtronics is no longer up that I can find.
There was a thread here about Craig from www.Moates.net making an alternative of a somewhat similar nature. Can't say if I found what was being referred to but, I didn't try to look very hard either.
Take a look at this link to see if it will work for you.
http://www.moates.net/gp3-switcher-a....html?cPath=64
Others here will know far more than I.
There's always the EBL as well.
Transmission: 5-speed/T-5
Re: Prominator
I have 2 Ostrich 2.0s.
One is "permanently" installed in my Datsun, and has been for over 2 years, the other I use on my test bench or for tuning other vehicles.
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Re: Prominator
Is the ostrich pretty easy to install and is it hart to learn to tune with? Im new to all this tuning stuff.
Re: Prominator
The Ostrich 2.0 is easy to install and use.
I use the emulator interface of Tuner Pro RT, which makes using the Ostrich 2.0 very easy.
BobbyK
Dec 16, 2004 08:39 AM
