beginner tunning 749
Old Nov 29, 2010 | 08:29 PM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
anyone wanna assist me in figuring out how to datalog/tune a 749 ecm converted for a 383?
let me know what software u suggest.
will have lots more questions
Shane
Old Nov 29, 2010 | 11:58 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: beginner tunning 749
Check out www.code59.org ... there you will find powerpoint documentation, bins and other helpful things...........
Datalog is the same as for any GM ecm.
Old Nov 30, 2010 | 02:17 AM
i have checked code59.org out and i get lost. im still trying to figure out how to get my laptop to connect to the ecm... hmm
Old Nov 30, 2010 | 05:22 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Do you have any chip burning experience before this?
What gear your using and do you have a WB02 sensor?
Old Nov 30, 2010 | 04:48 PM
i do not have any experiece burning chips. a few times i have been able to connect my laptop to my old 730 ecm with my 350 and datalog, but i cannot do it with the 749 ecm on my current 383.
the only hardware i have is just an usb aldl cable.
the wideband i have is just a Autometer wideband.. i have heard from people that they are not very accurate. so i was considering a different wide band when i figure out how to tune.
Old Nov 30, 2010 | 06:59 PM
Tony89GTA's Avatar
Car: 89 GTA
Before go to deep into things there are a couple of options you might want to look into before you start, first if your going to stay with the 749 ecm you will want to use code59. Basically a bunch of guys got together and modified the GM code and made it much better and easier to use. Only downfall I find is it takes a little bit of know how to setup a proper bin since the starter bins are all based off of turboed v6's.
Another option is EBL from http://www.dynamicefi.com/ looks to be based off of our V8's, you would be able to run your emision equipment if you need it and I believe it has a learn function which would make life lot easier. Plus I think it's cheap and you would get lot of help from this forum.
Lastly you could go with the new Holley HP EFI, it's definitely more expensive then the other two options but looks like it would be easier to use and has a learn function also. This is something I might look into the future since I'am kind of sick of messing with GM tables and spending time manually hashing out fuel tables plus converting over to SFI might be nice. Here is a link to a guy that's going to give it a try, I'll see how it works out for him before I decide to swap over https://www.thirdgen.org/forums/dfi-...ey-hp-efi.html
If you do decide to stick with the code59 I can probably help you with a starter bin but I'll definitely need to know more about your combo.
This is what you will need for running code59:
Download TunerPro5 here http://www.tunerpro.net/beta/tpbeta.htm
You will need these files for your tunerpro5, one is for your scantool and the other is for modifying your bin.
http://www.code59.org/index.php?opti...=7138&catid=13
http://www.code59.org/index.php?opti...=7193&catid=13
Use this for a base for your starter bin but will be needed to be modified for your V8 car http://www.code59.org/index.php?opti...=1925&catid=10
I can send you my bin also but it was far from perfict, never had the time to work on it much.
Old Nov 30, 2010 | 07:09 PM
Tony89GTA's Avatar
Car: 89 GTA
Oh yeah forgot to add I'am running Autometer wideband also, I find it works fine but datalogging with it shows a difference of .2 AFR between my dash and what my laptop shows. I created a custom table in the bin to make the laptop match what the dash shows now, hopefully it's the right number lol.
fasteddi
Sep 2, 2015 10:29 AM
bdads
Aug 24, 2015 06:01 PM
Blk_84_V6
Dec 4, 2001 08:20 PM
CanadianBeast
Jun 29, 2001 11:01 AM
SATURN5
Jan 25, 2001 12:07 AM
