165 8192 command?
Old Dec 2, 2010 | 12:25 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
165 8192 command?
Well after about 2 hours of searching, i came up empty. I am looking for the right byte string for 8192 baud communication with the 165 ECM frunning a $6E mask. I broke down and bought the USB cable from ALDLcable.com so i know its not my cable. In any event, I can not seem to get Tuner pro to connect, and when I do i get garbage data. Datamaster seems to work ok although some of the MAF g/sec data looks incorrect. EFIlive connects with no problems but again some of the data is displayed incorrectly. I am using the NTRPMX bin that bl85 created. Datamaster returns some "unrecognized data" sometimes. Since EFIlive does not give me any connection issues, I would like to know how to get the MAF and BLM data to display properly. Also i would like to know the exact byte string for the connection command for 8192 baud.
Old Dec 10, 2010 | 01:39 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: 165 8192 command?
Tunerpro RT
Tools > ALDL/Data Logging > Setup
Open the 1227165_6E.ads datastream.
Click the button Edit ALDL Datastream Definition and make sure that the check mark that says 160 Baud is NOT checked.
Put the jumper on the cable between A and B to use the 10K resistor:
http://www.obd2allinone.com/aldl-USBinstructions.pdf
Connect to ECM...
Also, check your COM ports, I think 8192 should be 9600 baud rate
69GTOby
Apr 18, 2016 02:34 PM
sreZ28
Oct 22, 2015 08:21 AM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BBSDesigns
Sep 22, 2015 03:08 PM
