Who's had problems with a willem burner? (damn chinese junk)
Old Feb 27, 2011 | 01:26 PM
helo's Avatar
ARGH- Fuqin' flaky transistor (Q2) controlling vpp (or a flaky solder or something).
I can sometimes coax it to erase by prodding Q2 with the multimeter.
I can't believe somebody thought it wise to use a $0.001 transistor instead of a larger $.008 transisotr. I mean, really... wtf.
Update:
After reading into it for an hour or so, there are A LOT of willem-based boards out there. I got shafted with a crappy one from ebay. I'm pretty good at soldering and I honestly don't think I can repair my board because all the components are crazy small. Live and learn
I'll probably stick with the willem if I can find one with better components.
Last edited by helo; Feb 28, 2011 at 08:20 PM. Reason: blah. fqin' chinese electronics.
Old Feb 28, 2011 | 04:42 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Who's had problems with a willem burner? (damn chinese junk)
sounds like it's easily replaced IMO...
which version anyway, the 4 series seems to be pretty solid from what i'm told.
Old Feb 28, 2011 | 05:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I have no problems with my GQ-3X.
I did replace my Dual Power programmer, that seemed to ruin some EEPROMs that I was using at the time.
I also have a BURN2, that is awesome and I have in my tuning bag to use when I go tune other people's vehicles.
Old Mar 1, 2011 | 06:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Update:
Have you contacted the seller of the burner? Is this a new burner? If so then it should have a warranty of some nature. Electronics do fail in the short term. I'd think that if there was a flaw in the selection of components that you would be hearing about a higher then normal failure rate.
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
