What EBL for '90 TPI?
Car: check
Engine: check
Transmission: check
Re: What EBL for '90 TPI?
Yes. Just double check which ECM is being used first. A '90 TPI will use the '7730 which has two black connectors and a yellow or light-green third connector.
Note that the ECM may also be labeled (Service Number) as the 16198262 or 16196344. All three are the same.
RBob.
RBob.
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Car: 93 Mustang GT
Engine: 5.0
So that is all I need to know to order? Just debating on the TT-1 or AEM wideband right now? Any kind of deal on the TT-1 if bought with an EBL?
Car: check
Engine: check
Transmission: check
RBob.
Here's a question Bob. I already have the EBL Flash for my TBI car. Can I send it to you and convert it to work with a 91 L98 car? or do I have to purchess the P4 system? I would like to retain the use of the EBL system even after I swap to the LT1 in my current car.
Car: check
Engine: check
Transmission: check
If you swapped an L98 into your car the EBL ECM can be used when updated with the Port Mod. Only other change would be to wire up for the injectors, TPS, and IAC.
RBob.
A little confusing, a '91 L98 car would be better off with the EBL P4 ECM. It is plug & play with that vehicle.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
RBob.
Originally Posted by RBob
Yes, for the '91 L98 car the EBL P4 is the one to get. Unplug the stock ECM and plug in the EBL P4 ECM, slide back into holder. Otherwise it is a whole bunch of re-pinning and adding a VSS buffer and knock filter....
Car: check
Engine: check
Transmission: check
RBob.
Sanjay
08-12-2015 03:41 PM
