$32B Mask Spark Advance Question
Old Mar 4, 2011 | 04:43 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi,
I am working on tuning my 355 LTR setup.
I need to add some SA during cold coolant temperature conditions to keep the engine running well. At least long enough for the water temperature to approach the 180 °F nominal running condition.
I have finally locked-in the normal operating temperature SA vs. Load vs. RPM table.
Now I am working on the "Cold Temp Start-Up" Spark Advance optimization.
Ignoring the details of the Start-Up Spark Advance Decay-Delay and Spark Advance Decay time properties (working fine), it is my understanding (from reading the HAC) that the total SA is determined as follows.
1.
Look-up the "base" SA based on Load and RPM (2D Table).
This table works great for nominal coolant temperatures (180°F).
2.
Compensate the "base" SA based on Coolant Temp vs Load (2D Table).
3.
Add the Start-Up Spark Advance offset as a function of Coolant Temp
(1D Table). This value is decayed out long before the coolant temperature increases significantly. Just a start-up mode event.
Based on the TunerPro RT data log, it looks like the SA compensation as a function of Coolant Temp vs Load was not included.
Is the above reasoning correct?
I dug a little deeper into the HAC and found an interesting parameter.
Address : 0x2B : Disable Cold Spark Advance if Coolant is > Threshold.
The present parameter value is -40 °F.
Does this parameter act as an override to the SA Compensation vs. Coolant Temp vs. Load Table for temperatures below the threshold?
I also found a Hot Spark Retard parameter at address 0X29. It looks like this parameter enables a hot restart SA retard if the Coolant Temperature is > a programmed threshold.
Any help would be much appreciated.
Best Regards,
Bruce
Red iroc-z 305
Sep 30, 2015 05:22 PM
redmaroz
Aug 16, 2015 11:40 PM
tmellott89
Aug 16, 2015 02:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
