tunerpro V5
Old Apr 13, 2011 | 11:15 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
tunerpro V5
Nevermind - I forgot to update preferences.... doh!
Old Apr 13, 2011 | 11:25 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: tunerpro V5
With the APU1 set for "moderated" mode, check device manager for the correct port it is connected to. It should be listed there if it is found.
Edit the port settings and change the latency per the instructions.
(set to 1 IIRC) and save/exit.
Then confirm the port is setup in TP correct.
After that, try to connect in pass through mode with the switch away from the connector on the AutoProm.
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
