Looking for a adl cable
Old Apr 20, 2011 | 02:38 PM
herbz28's Avatar
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
I am looking to see if anyone has an adl cable that is usb and also works for a odb1 car. I have a laptop and all the software just not a cable and was hoping someone had a spare one that they didnt need anymore. i would really like the usb one but if you have a serial port one that could work too. My computer has usb and also has the serial port to hook up an external monitor. anyways thanks again for all the help and i love this board. Just pm me if you have one or email me at hhall@crexendo.com. thanks again guys/gals
Old Apr 20, 2011 | 04:24 PM
88gunmetalgta's Avatar
Re: Looking for a adl cable
That's not a serial port, its a VGA port.
Old Apr 20, 2011 | 04:28 PM
herbz28's Avatar
Engine: 5.0 tpi
Transmission: 5spd
my bad then i would need a usb one then
Six_Shooter's Avatar
Transmission: 5-speed/T-5
www.moates.net has a USB based ALDL cable, that works great.
Old Apr 20, 2011 | 04:33 PM
herbz28's Avatar
Engine: 5.0 tpi
Transmission: 5spd
Yeah i know they have them but i do not have the 80 bucks or whatever they are charging for a cable. I was hoping someone on here had a spare one they would be willing to part with at a small price. I guess i could try to make one or something
Old Apr 20, 2011 | 06:56 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
someone on the TP forums shared a link with a UBER cheap FTDI based serial-USB converter that only required i think 3 wires to be soldered and it worked?
http://forum.tunerpro.net/viewtopic.php?t=2399
Old Apr 21, 2011 | 03:18 AM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
That's interesting, I may get one for experimentation.
I have a few retrofit project cars where it would be cool to just have a permanent ALDL adapter installed and just have a simple USB jack. Then just use a common usb data cable to the laptop.
Old Apr 21, 2011 | 08:55 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
indeed, i've built a few of those before, be warned that apparently you have to switch the M wire on and off to allow other ALDL based devices to work? i had someone with a Tech1 play with it and they got the diagnostic check to pass, but whenever they tried to recieve data, it just never connected..... their DIC seemed to work though, so i don't know what is going on there.
i find it interesting that the MAX232 isn't required to condition the circuit though, but as noted, it seems to have a latency advantage when it does....
i may pick one up myself.
Old Apr 21, 2011 | 09:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For the bouncing lower the latency setting (see link at TP forum). The MAX232 isn't required as the ALDL link is 0 to 5 volts. Not the -8 to +8 volts (or there abouts', it is a wide range) that an RS232 serial link uses.
RBob.
Old Apr 21, 2011 | 09:37 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
interesting...
i have no pause built into any of my definitions, the only latency i see is just how the laptop has it's port setup from the USB-serial driver, i think it is ~16mSec, i've never messed with the value before... i may play with it when the GP is up and running again.
i did find it odd that the OP in the TP thread still needed additional pauses built into their definiton to stop the ALDL glitches though.... maybe that is a laptop specific issue though? i may order one and see how my laptop reacts when there isn't a MAX232 between the USB-serial converter and the ALDL port... if there are glitches with no pauses added, i'll integrate it in, see if it clears it up....
i would think less complexity would work better though.
Old Apr 22, 2011 | 12:12 AM
Ok, so I can just add a toggle switch.
I'm involved with about 6 different retrofits right now for myself, friends and family. I've been telling them all that they will have to get USB ALDL cables to send me datalogs and do their own diagnostics. Problem is that ALDL cables get lost or damaged especially by people who never really use them. A plain old USB cable on the other hand is easy to acquire or replace.
Old Apr 22, 2011 | 10:08 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
true.
i really don't know why integrating a USB ALDL cable basically stopped the ability to communicate when it's M pin is connected, but it worked.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
