89 Iroc datalog sporadic data Help!
I have a 1989 Iroc with a 350. Only mods are headers and custom dual exhaust, AIR removed. AFS-74 3-wire O2 installed.
I am new to tuning these engines and would appreciate any help you all could give.
I have looked on various forums and tried everything I have seen to fix this problem and nothing seems to work.
I am using Tunerpro RT and a moates autoprom unit.
I have loaded the 6E xdf and 1227165_6E adx from tunerpro's website
The problem is whenever I try to datalog I get useless information and the number just start jumping sporadically.
This is a youtube video of the issue.
http://www.youtube.com/watch?v=SSstGLaLI1k
I have tried adding in a 20ms pause as I saw suggested for a similar problem on the tunerpro forums but it didnt help.
With all this being said, there have been a few instances where I did get good data out of the system but i would change screens and the it was back to this sporadic data again.
I would appreciate any help regarding this matter.
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Re: 89 Iroc datalog sporadic data Help!
Did you ever resolve this? I have a an issue that I get all the correct readings and then random garbage every 10 seconds or so. I am hoping there might be something in common.
mustangman65_79
Aug 11, 2015 03:17 PM
