another datalog problem thread(S_AUJPV4)
Old Jun 9, 2011 | 02:42 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
i really hate to post if i can search first. but i think this time i cannot find the answer. i need to ask if im configuring everything right before i melt something.
7730 running saujpv4 and saujpv4.adx
tested ecm by paperclip method, flashes code 12 only
changed ports from 3 to 8 and set latency to 1, no luck
preferences set to corresponding port setting.
restart lappy and TP and test connection via TP, says its functional, ect.
lappy with win 7 and even configured to run in XP(SP3) mode, no luck
aldl connections; orange data at M and E, ground at A, and CEL enable at B
does it seem like im missing something? JP is walking me thru when he has the time. is there a sticky for this type of problem ive overlooked? TIA hope to have this POS on the road soon lol
Old Jun 9, 2011 | 06:41 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: another datalog problem thread(S_AUJPV4)
You didn't state what your problem is.
Old Jun 9, 2011 | 06:53 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
LOL oops
im not getting any data while using TPV5. says its connected but im not seeing any data.
Old Jun 9, 2011 | 07:07 PM
Have you tried V4?
What cable are you using?
Old Jun 9, 2011 | 09:37 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Have you tried V4?
no i havent but i could try. i have moates extreme aldl set to open. thanks
*edit* tried on v4 but i have to find a saujpv4 version that will work with tpv4
Old Jun 10, 2011 | 12:59 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Any $8D definitions work with the S_AUJP and TP V4.
Its still the $8D datastream, You just won't see the extras until added.
Grab the one from the TP site and try it and see if it connects.
Sounds like you have everything right.
Old Jun 10, 2011 | 03:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
At key-on, engine-off, measure the voltage on the ALDL connector pin M (to pin A). Should be 5 volts. Not long ago a fellow here was pulling his hair out trying to connect. Ended up the ECM was bad. Pin M was showing a lower then correct voltage.
RBob.
Old Jun 10, 2011 | 06:35 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
If it's of any help, I've been previously informed that data logs from TP V4 will not play on V5. Sounds like you haven't got quite that far yet. Apparently the .ADX vs .ADS files are not the same, and are not interchangeable between V4 and V5.
Old Jun 10, 2011 | 07:26 AM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
RBob.
i remember seeing that so i went out last night and checked. there is +5V present.
Old Jun 10, 2011 | 09:24 AM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
ok i got it to work, i used the import ads feature for the saujpv4.ads. it doesnt have all of JPs nifty guages and dash layouts though. since ive been using winaldl im not all that familiar with tp either. im used to seeing the tables right on the screen so now i need to search for them lol. thanks everyone!
Old Jun 10, 2011 | 09:58 AM
lakeffect2's Avatar
Holy Cow ! You mean I might have actually helped someone instead of needing to get bailed out? (or balled out) That's a first!
Congratulations on your success.
Dave
ZMWojnar
Brakes
May 12, 2019 10:43 PM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
