Starting Problem - Vid attached
Old May 22, 2011 | 10:04 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Sorry for the sucky video, it was taken on my cell phone.
This is what happens when starting the car (cold/warm).
The CSI is unhooked and the fuse is pulled.
I'm trying to figure out what would make this happen. There are LOTS of new parts on the car. It has new plugs, wires, cap, rotor, injectors, fpr, maf, iac etc.
It has happened since I went from 32B to 6E. I'm running a bin from an 89 350 automatic car. It used to crank for about 2-3 seconds before starting, but I have played with some of the cranking things in the bin and have gotten it to start pretty much instantly when cold. It take a little longer when its warm to start.
I think it might have something to do with the cranking, or crank fueling, but what?
EDIT: COMPLETELY stock engine.
Old May 23, 2011 | 04:13 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Starting Problem - Vid attached
Do you have a wideband? Even though they are not real accurate during a start-up situation, they can give some clues as to what is happening with the fueling. This could be a possible lean issue after the engine has caught, and transitioned from the crank fueling to the MAF.
Old May 23, 2011 | 05:16 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
No, I dont have a wideband. So your talking that it could be lean from the transition from crank fueling to the fueling in the 1st MAF table?
Old May 23, 2011 | 07:03 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I played around with the fueling today and richend the mixture on the maf tables with no change.
I am out of ideas, unless it is a sign my fuel pump is on its way out??
Old May 25, 2011 | 12:11 AM
JamesLLeary's Avatar
Car: 1986 K10 Suburban
Engine: 5.7 TPI Speed Density
What is your Injector flow rate set at? And what was the reason for changing def......Get rid of the cold start injector?
Old May 25, 2011 | 05:16 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Its set to 22.xx. Whatever was stock on an 89 350 chip.
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
