Looking for a Manual bin for 16197427 PCM
Old Jun 9, 2011 | 05:30 PM
EagleMark's Avatar
Looking for a Manual bin for 16197427 PCM. Was there ever one from GM? Maybe I am dreaming but I swear I saw one somewhere...
Old Jun 9, 2011 | 06:17 PM
93V8S10's Avatar
Re: Looking for a Manual bin for 16197427 PCM
I've got these:
BHFM, $0D, 1994, S1, PFI 2.2L L4(CAL), Manual, 8505
BHRD, $0D, 1994, L1, CPI 4.3L V6(FED, ALT), Manual, 6395
BNBJ, $0D, 1995, L1, CPI 4.3L V6(EXP), Manual, 7427
I think they all came from the Moates server.
As far as I know, there are no V8 manual bins.
Old Jun 9, 2011 | 07:01 PM
EagleMark's Avatar
Thanks! Looks like that export one may be best to start with, then import some 5.7L paremeters...
Old Jun 9, 2011 | 09:34 PM
jim_in_dorris's Avatar
EagleMark, are you looking at a manual bin because of a tranny or other tuning parameters? Converting a $0D bin to manual is fairly simple,
L400E FCB $04 bit 2 on for shift light
L400F FCB $98 bit 8 on manual trans bit 4 cat overheat, and bit 3 knock retard.
That's pretty much it.
Old Jun 9, 2011 | 09:42 PM
here are 2 manual bins for 350's
BJDT BJDU from moates lookup. out of 94 G3 platforms. I can't find a copy of those bins.
Old Jun 10, 2011 | 07:36 AM
EagleMark's Avatar
Thanks Jim I will look for them. So far my research showed the 4.3L to be the only manual trans bin for that ecm/pcm... then I found there are 2 in CA because of emmissins the vehicle needed the EGR pintle operation.
So GM used their 427 instead of a 7747... but I think it was the 395.
Old Jun 10, 2011 | 09:21 PM
93V8S10's Avatar
I agree with jim_in_dorris, just convert a V8 bin over to manual. I'll be a lot simpler.
Old Jun 11, 2011 | 08:46 AM
EagleMark's Avatar
Taking both your advice!
Reason I was looking for a manual bin was not knowing if changing an auto bin to delete/auto would end up with the decel valve type situation that manual trans had even before ECMs. I think it was installed as a pollution control device but did make driving a manual trans shifting easier.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
