code 51 troubleshoot help
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
just check whats my trouble code and it is trouble code 12 and 51 ? i have 89 camaro rs 5.0 tbi with k&n air filter and 2.5 in exhuast with flowmaster last owner had removed the cataylitic converter car runs fine idle is around 2500 i belive i drove 100 plus miles the other day only isssue is it runs 250 for coolant temp i just got 160 thermastat new coolant temp sensor and about to flush fluid with water then put in 50/50 mix as got airdam and chin spolier off 90 camaro i know its either the prom or ecu but not sure where to start to troubleshoot
Car: check
Engine: check
Transmission: check
Re: code 51 troubleshoot help
Code 12 is normal and expected. Code 51 is a bad PROM. If you ran the engine with the PROM removed code 51 will be set.
At key-on, engine-off look for the SES blink.
The SES should light up, blink off, then light up solid. If it does that you are good to go.
Note that the fan is not under ECM control. It is controlled by the head switch between 6 & 8, and the A/C system.
There are three coolant temperature sensors/switches. One for the dash gauge/light, one for the cooling fan, and one for the ECM.
RBob.
RBob.
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh ok i think it just constantly blinks on key on engine off ill double check if "SES should light up, blink off, then light up solid" what sensor is by the themastat neck on top of the intake manifold i compared it to the new sensor and looks alike ill look for the sensor by the head to
thanks alot RBob
thanks alot RBob
Car: check
Engine: check
Transmission: check
thanks alot RBob
thanks alot RBob
If the sensor has two wires, a yellow and a black, that is the coolant temperature sensor (CTS) for the ECM.
RBob.
Engine: 305 to 350
Axle/Gears: 10 Bolt
OK im going to check that out then
