shutting off deceleration fuel cut off... how to? 7730 pcm
Old Sep 7, 2011 | 05:01 PM
mistaben's Avatar
Car: 91 corvette
Engine: 383SR
so this along the lines of doing a manual VE tune without power enrichment mode on.
i also want to shut off fuel cut off on deceleration, so i can drive my car around and get a good datalogging and tune the ve tables correctly then put the accel and decel on. is there a write up on how to do that too? which are these options?
a not less than or more than?
Old Sep 7, 2011 | 09:14 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: shutting off deceleration fuel cut off... how to? 7730 pcm
I don't see how disabling DFCO will help tune the VE tables. Anytime DFCO is active, is when the engine is come back down to an idle or near idle, as in vehicle decel, when you don't want fuel to be injected anyway.
Old Sep 7, 2011 | 09:31 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
WHen they extra fuel you don't ned hit that hot exhaust, get ready to blow apart your muffler system at a weak point. Ask how I know..........
[using a manwich can right now to patch where mine blew apart]
Old Sep 8, 2011 | 10:48 AM
Ronny's Avatar
Dont forget to turn back on PE. I dont think PE will be invoked if you are easy on throttle and creap up on rpm/map you desire to log. See what DFCO tables offer. you may be able to change one to disallow its use. I will see what mine are.
OK. raise enable temp or raise TPS enable to 99% or set MPH to 150 or set RPM to 7000
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
wayshegoes
Aug 17, 2015 12:00 PM
djmarch
Aug 9, 2015 05:27 PM
