Are there upgrades to the embedded ECM software ?
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I have a 1988 TPI L98 and have been reading a bit about the EPROM customisations and bin tables.
One question I haven't see answered is "Are there upgrades to the embedded ECM software?"
My understanding is that the ECM uses a Motorola 68K embedded processor running code written in Assembler.
Did the factory ever release upgrades/updates to this Assembler code as source or binary and is it possible to install this?
Car: check
Engine: check
Transmission: check
Re: Are there upgrades to the embedded (assembler) software ?
I have a 1988 TPI L98 and have been reading a bit about the PROM customisations.
One question I haven't see answered is Are there upgrades to the embedded (assembler) software?
There isn't much for the MAF TPI ECMs. However, there is a WB input patch that can be used to data log a WB set up along with the other ALDL information.
For the SD TPI engines there is super AUJP (SAUJP) which has extended VE tables in it. Along with some other changes.
The factory always releases the code as a BIN as it is in the PROM that way. There are hacks of various BINs. Where it was disassembled, formatted, and commented.
RBob.
Transmission: T700
@RBob,
thanks for the reply.
Any suggestions where I could get updated PROM ECM embedded code?
Did GM ever release any updates or maintenance releases to this code?
Billy Decker
Sep 4, 2015 03:46 PM
