Showing voltages in tprt 5 datastream
Old Nov 25, 2011 | 01:47 PM
formulax4's Avatar
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
Hi,If this is explained somwhere here in the forums i have over looked it.My question is i would like to monitor all the sensor voltages as the ecm sees them.How can i do this? Many thanks!
I have gained some knowledge from a post here
https://www.thirdgen.org/forums/diy-...f-voltage.html
edit:I am using the 6e bin and definition ect.
Old Nov 26, 2011 | 10:30 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Showing voltages in tprt 5 datastream
The ECM converts 5 volts to an 8 bit value.
5 / 255 will give you Volts reading.
Create additional items or change the existing conversion formula.
Old Nov 26, 2011 | 06:35 PM
formulax4's Avatar
Car: 87 GTA
Not sure i understand the whole equation thing.Could you expand a little bit on the subject for a newb? It has been a heck of a learning curve for me so far.I greatly appreciate it! Talking to me as if im a child might help Im just an old child!
Old Nov 27, 2011 | 08:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For the conversion use:
(5 / 255) * X + 0.000000
or, reduced:
0.019608 * X + 0.000000
RBob.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
3.8TransAM
Oct 1, 2015 07:47 PM
