EBL-PE adder
EBL-PE adder
Is that the SA-PE vs gear?
EBL.bin has it zeroed out. so SA is in Main and Extended?
Yet Zero gear has 2.8 800 rpms and 4.22 at 6400 rpms.
Is zero park neutral? Why does it exist?
Car: check
Engine: check
Transmission: check
Re: EBL-PE adder
RBob.
Re: EBL-PE adder
OK. Thank you.
N/V flag set. Do I zero out value for the Zero column 800-6400? I did so.
Then at #1 I have 2.81 #2 2.46 #3 2.46 and 4th gear of 4 I have 2.11
Is that correct?
Is that correct?
Car: check
Engine: check
Transmission: check
Re: EBL-PE adder
I would make gear 0 the same as gear 1.
The N/V ratio table also needs to be filled in with the proper values. Basically it is RPM divided by MPH and reduced by 10% (this is for the xxxLo entries). Then for 1stHi, split the difference between 1stLo and the number 255.
RBob.
Re: EBL-PE adder
For the above you've pulled 0.7* of timing from 1st to 4th, so not much of a reduction.
I am adding 3 for first gear then 2.5 - 2.5 then 2.0 for fourth of four gears. PE adder right? If it is a reduction where is the PE adder table?
Car: check
Engine: check
Transmission: check
Re: EBL-PE adder
I need to clarify the above. Why do you say it is a reduction? Is not that gear table an adder of PE? I looked in your intro part 2 but did not see any explanation.
RBob.
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Re: EBL-PE adder
Anyone get this figured out yet in English? I'm an engineer but not a computer engineer
sailtexas186548
Aug 24, 2015 10:11 PM
383TAGTA
Oct 15, 2001 05:44 PM
