Can a 400 SBC be built to reliably handle a Power Adder?
Old Oct 14, 2001 | 11:42 PM
383TAGTA's Avatar
Car: 1987 GTA originally 350TPI 3.27posi
Engine: 383 C.I.D.
I have a chance to get a hold of a 400 SBC bare block "Virgin" never been bored out and if I decide to buy I'm going all out with either a D-1SC or at the least a 150hp shot. I like to build an engine to handle the rigors of daily driving and strip action although more like racing in between
So my question if its possible then at what cost? Plan B is a Bill Mitchell assembled 427 Short block for 4600.
Just seeing if theres any 400 out there running a power adder and would like their thoughts
Old Oct 15, 2001 | 04:19 AM
89ProchargedROC's Avatar
my bosses nova goes 8.80s with a 2 bolt factory 400 block with a fogger and splayed 4 bolt caps with water filled jackets
with a blower.....the hp limit goes down because of all the pressure you are constantly giving it, for blowers your limit is about 10.0
Old Oct 15, 2001 | 07:30 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
well im doing a SBC 406 and it can take a 200 shot with no problems.. then again, i have all forged internals and custom ROSS racing pistons. but im sure a 150 will be no prob
Old Oct 15, 2001 | 05:44 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
I have a 2-bolt block that is now splayed with billet caps also,but the water jackets are not filled. Although its not my daily transportation,I drive it pretty often.Right now I`m spraying 150 and so far so good.Factory blocks have thin cylinder walls which is where the trouble lies.I know of 1 400 which swallowed 15# of boost and ended up with a cracked cylinder wall.IMO,if you`ve got the coin to consider the Bill Miller peice, do it!!The Motown is far superior to any production 400 block even at 427ci
91Z28 406,mini-ram,Track-1s,232/242 roller,Wiseco 9.5:1 pistons,6"Eagle rods,Callies crank,Speed Pro EFI w/ wide band,Weldon 2015,Nitrous Express 150,Turbo350 w/ 10"ATI,12-bolt 373s,Southside bars,Centerline Warriors,28x11.5 ET Streets Best N/A: 11.22,120mph...10.41/129 with 150 shot
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
sreZ28
Aug 14, 2015 07:48 PM
