Stock EPROM isn't in my P.Programmer software list. Help pls!
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
I'm burning/reprogramming a stock eprom without desolder it from the memcal.
The erase process was succesfully, but my programmer sofware ask for eprom brand and type, but this stock GM eprom has the following printed codes in its brown surface section:
014
045915
AM8827B
(Memcal pulled off from an 1989 2.8 V6 olds. with 1227730 ECM).
This "AM" eprom is not in my list from the programmer software.
What can I do in order to burn the eprom choosing the right brand - type for programming process ?.
Any help will be appreciated
Thanks in advance,
Denis V.
014
045915
AM8827B
Thanks in advance,
Denis V.
Car: check
Engine: check
Transmission: check
Re: Stock EPROM isn't in my P.Programmer software list. Help pls!
Hi,
014
045915
AM8827B
Thanks in advance,
Denis V.
014
045915
AM8827B
Thanks in advance,
Denis V.
RBob.
Axle/Gears: No idea
Thanks a lot!
I tried but it seems my eprom is failed since only save new data from 0000 to 2606 internal location. From 2607 to end, this eprom still with "FF" (erased data).
Thanks again,
Denis V.
Thanks again,
Denis V.
Genopsyde
Oct 7, 2015 08:35 PM
