Help reading winaldl log
Old Apr 21, 2012 | 09:14 PM
V8-YJ's Avatar
Car: 1989 Jeep YJ
Engine: 1990 L05
Transmission: sm420
Axle/Gears: 4.10
I have been experiencing a lean miss on a modified 1990 lo5 in a jeep YJ has anyone experienced a problem like this before?
The motor has the following modifications:
.060 bore
Vortec heads
9.3:1 compression
50mm throttle body with bored intake and two matching one inch spacers
Cam .204/.214 dur. with 286/301 lift
68# injectors
1228746 ecm
Compu-tronix dis8 ignition
Custom Fastchips prom
This is the first data log as we are new to modified throttle body injection. I have included the log. Any help with an explanation of what the data log shows would be appreciated.
File Type: txt
Old Apr 22, 2012 | 07:00 AM
EagleMark's Avatar
Re: Help reading winaldl log
Reading RAW values is pretty tough and WinALDL is so 2007. Do yourself a favor and get TunerPro RT and the def files and you'll have a lot more to work with.
http://tunerpro.net/downloadApp.htm
Old Apr 22, 2012 | 04:29 PM
V8-YJ's Avatar
Car: 1989 Jeep YJ
Engine: 1990 L05
Transmission: sm420
Axle/Gears: 4.10
I downloaded the TunerPro RT program and cannot figure out how to acquire my definition log for data stream for the 1228746 ecm. If I save it as a .adx file the program cannot find it.
Old Apr 22, 2012 | 06:19 PM
EagleMark's Avatar
TunerPro Tutorial:
http://www.gearhead-efi.com/Fuel-Inj...ro-Tuning-Talk
ADX is the file that logs the data. Acquisition, Load Definition file and choose your ADX.
With your cable hooked to car and laptop with TunerPro open Acquisition Start Stop Data scan and you should see data.
Then to record, Acquisition, Record, when done Acquisition, Stop, and you'll be prompted to save the data in a XDL file with a name.
Old Apr 22, 2012 | 06:49 PM
V8-YJ's Avatar
Car: 1989 Jeep YJ
Engine: 1990 L05
Transmission: sm420
Axle/Gears: 4.10
I figured that out and logged the data but cannot figure out how to read it. Do i need another program to open this file? I can play the file in real time within TunerPro, but i would like to put it in an email to send it to my tuner. (FastChips) Also is there a way to post it in this thread?
Old Apr 22, 2012 | 08:08 PM
EagleMark's Avatar
This is DIY Prom! If your not going to DIY I would ask him what he wants and how? After all he's making the bucks...
Old Apr 23, 2012 | 12:21 PM
V8-YJ's Avatar
Car: 1989 Jeep YJ
Engine: 1990 L05
Transmission: sm420
Axle/Gears: 4.10
Well, for one, he was the one who asked for the file formatted. And for another TunerPro took me around two and a half hours to figure out how to log. Like I said, I am new to this and I would eventually like to be able to burn my own chips, but before that i have to learn how to read all of this data. If i wasnt interested in the DIY section this post would not be here. And yes i did figure out how to export from TunerPro on my own.
If I need to post a thread like this in a different section just let me know, cause so far none of my questions have been answered.
Old Apr 23, 2012 | 12:34 PM
EagleMark's Avatar
If you have logged data in TunerPro you can play it back in Tunerpro and watch Item lists, dash boards or monitors. All of which can be set to do exactly what you want!
You can also export the data log into a spreadsheet format as a whole or just the recorded data signals you want to see or use. Acquisition Export Log.
Right click on toolbar and check all toolbars so you can get used to the buttons and icons. Or go to Acquisition Play or Acquisition Dashboard. Lots of options and all customizable. Just open things and look, while in monitors or dashboard right click to choose the value you want to see!
Old Apr 23, 2012 | 02:20 PM
Ronny's Avatar
I used winALDL quite a while ago. I recall it will show you when it is in CL(flag) and provides BLM data in your RPM/MAP cells so you can change same in VE table to achieve the desired 128 for BLM or INT for that matter. WinAldl is pretty basic stuff. It may provide knock counts as well. I believe you posted raw data as stated. Most of us graduated to RT or more sophisticated logging programs.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
