tunerpro rt v5 problem
Old May 9, 2012 | 06:10 AM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Hey was wondering if you guys could help me out im having the issue with the errors every couple of seconds. I really dont understand where to add the pause to fix it.
Old May 9, 2012 | 10:58 AM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: tunerpro rt v5 problem
http://forum.tunerpro.net/viewtopic.php?t=2215
Here's some pics to help you.
Old May 9, 2012 | 11:30 AM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Thanks ive read that thread and when i went into the commands section I didnt have mode 1 or mode 8 listed so I have no idea where to put the pause. Im using the basic 730.ads file.
Old May 9, 2012 | 05:28 PM
TORN's Avatar
Car: 88 IROC-Z
What modes are listed?
Old May 9, 2012 | 06:06 PM
TORN's Avatar
Car: 88 IROC-Z
I put mine after: Mode 1 ALDL Dump Request Macro
I am using ECM 1227165
click add new item.
select, listen to silence.
put 20 where its says timeout (ms) 400
save and run some had to move that number higher.
I didn't get a chance to test it, so if it doesn't work just delete the line you added.
Old May 13, 2012 | 02:08 PM
TORN's Avatar
Car: 88 IROC-Z
found this on you tube: http://www.youtube.com/watch?v=xYCfx6rCNM4
GTAman
Sep 21, 2015 09:57 AM
IroczInOz
May 13, 2005 06:43 AM
TheGreatJ
Mar 8, 2005 09:09 PM
jonarotz
Jan 7, 2005 10:32 PM
RBob
Aug 23, 2004 08:00 AM
