PE mode
Old May 13, 2012 | 03:55 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
PE mode
When in PE does the block learn numbers show or do
they set at 128
Old May 13, 2012 | 08:04 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Re: PE mode
Know one knows, or did I word it wrong
Old May 14, 2012 | 07:33 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: PE mode
From what I've observed on my own data logs, it seems to lock the BLM's at 128, but the actual AFR reading is usually much richer than a BLM of 128 would indicate. It usually heads towards 12.5 (in my tune, can't speak for others) which is in the AFR area that max power would be expected to be produced.
Can't say I'm correct on this thought, or that others agree with it, but I tend to think of a locked BLM at 128 as a way for the ECM to ignore it, as it is during an event period where other commands have precedence. Same way with AE, DE and DFCO where BLM's lose their importance and give way to other commands.
Hopefully, others may feel free to disagree and shed light from there own observations as well.
Dave Buchholz.
Dave
Old May 14, 2012 | 02:00 PM
Ronny's Avatar
Re: PE mode
When you enter PE the ECU takes a look at the BLM just prior. If it is 135 (adding fuel) it uses it. If it is 122(removing fuel) it uses 128 for safety. My logs show 128 when in PE.
Rocket-Doc
Nov 14, 2015 02:08 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
327IROC85
Sep 23, 2015 12:11 AM
david068513
Sep 18, 2015 10:36 AM
ULTM8Z
Sep 16, 2015 09:15 AM
