IAC TF Decay filter and IAC Steps decay filterQ?
I see it is set high 9.75 and low 12.5 in stock LO3.bin. for TF. and 12.48 normal and 18.72 for St/SV(stall saver?) IAC steps.
Which way to move it to slow down its speed of movement over msec's?
Right now in log with slight AE event onset I move from 4 steps to 13 steps over 1.0 sec time. I would like to slow down IAC by about 25%.
I already moved TF min steps from 4 to 1. And moved TF TPS% Req 2 to 1.
this Q came from my thread "Bucking"
Car: check
Engine: check
Transmission: check
Re: IAC TF Decay filter and IAC Steps decay filterQ?
The TF IAC steps open as quickly as the throttle is moved, up to 160 steps per second.
The decay of the TF steps, a lower filter value is a slower decay.
RBob.
RBob.
