VSS signal charateristics
Old Aug 6, 2012 | 11:28 AM
Scorp1us's Avatar
I am looking at making an even more painless VSS solution for retrofits. I am speficically targeting 16197427, but I can do one for the previous generation as well.
My plans are simple- to use a custom housing and a photo interrupter that will use a miniature in-line wheel on the speedo cable. This way you can change your VSS characteristics by changing your wheel. No more bolting rings below the vehicle.
I also might be able to add a gear information if a tach signal is provided. I'm looking for the signal charateristics for these pins. is is +/- 1v? 12v? etc?
Old Aug 6, 2012 | 12:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VSS signal charateristics
It is a simple open collector pull down.
RBob.
Old Aug 6, 2012 | 12:14 PM
Scorp1us's Avatar
Oh that is awesome, So if I understand you correctly, then I can just use a transistor and short it to ground directly from the photo interrupter?
Tach is the same way?
Old Aug 6, 2012 | 02:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Basically yes. The ECM side has a 5.1K pull up to IGN+, then into a buffer (inverter) with some filtering/protection. The optical/magnetic buffer boxes (4-0ut/DRAC/optical), just pull that line down and release it to form the square wave input.
There is a capacitor on the output of the buffer box to help protect the transistor.
Not sure about a tach signal, as there isn't one. There is the DRP input to the ECM, and the EST output (5V square wave). But I don't like messing with those as they are important to the proper running of the engine.
RBob.
Old Aug 6, 2012 | 02:23 PM
Scorp1us's Avatar
Oh ok, I'll take the EST then and compare it to the speedo and calculate the gear. Then I can express that as pins so I can get highway mode in addition to DFCO.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
