Idle hangs until i come to complete stop.
Old Oct 22, 2012 | 04:34 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Im in the process of doing some tuning now and i cant seem to find the answer of what to change to get ride of this hanging idle. Its very annoying. When i come up to a stop the idle is at 1500 rpms until i come to a complete stop and then it drops down to where it should be. I read some threads dealing with this but none of them really gave an exact answer for what is going on and what needs to change.
Old Oct 22, 2012 | 06:01 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: Idle hangs until i come to complete stop.
When I swapped a T56 into my 88 IROC Z I used APYP and modified the spark tables then started adjusting from there. APYP is the corvette manual 6 speed .bin equal to ARAP.
Old Oct 22, 2012 | 06:32 PM
subroc's Avatar
Engine: 355 TPI
This bin started out as an ARAP but is pretty modified from there. It needs some fine tuning but i really would like to get rid of this issue. Its pretty annoying to drive with.
Old Oct 22, 2012 | 06:35 PM
TORN's Avatar
Car: 88 IROC-Z
You do have the speedometer hooked up right. If its not the computer won't know how fast you are going and it will cause it to hang too.
Old Oct 22, 2012 | 08:03 PM
subroc's Avatar
Engine: 355 TPI
Yup its all hooked up.
Old Oct 22, 2012 | 08:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What TORN said plus the P/N input to the ECM. For a stick shift it needs to be open, not connected to anything.
Also do/check the minimum idle air set up. On the MAF TPI system it is critical for a decent idle.
Starting with ARAP, there is a setting in the IAC parameters to tell the code that it is a stick shift car.
RBob.
Old Oct 22, 2012 | 08:46 PM
subroc's Avatar
Engine: 355 TPI
For the park/neutral input are you referring to the neutral safety wires (purple and yellow if i remember right)? My car was formerly an auto and now is stick. It did this same thing with a TPIS chip. Then i started to do some tuning and fiddling with the minimum air. I could not get the tune correct so i put the TPIS chip back in and it did not do the idle hanging anymore. Then i started tuning again and did not touch the minimum air but the idle hang is back. Maybe i need to redo it again?
Old Oct 22, 2012 | 08:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Rbob and torn are referring to pin B10 of the 1227165 orange/ blk stripe need to be open not grounded.
Old Oct 24, 2012 | 06:17 PM
subroc's Avatar
Engine: 355 TPI
Yup its not hooked up.
As for the setting the iac (idle) i went through and did it all over again. I noticed now that i didnt use the paper clip across a-b. But at any rate i set the idle with the IAC disconnected to around 700 and then reconnected the iac. I took it for a drive and at first i thought that solved the issue because for the first three stops the idle didnt hang. Then about 5 minutes into the drive it started to do it again at stoplights. I thought that was too easy. Did not using the paper clip screw up the whole thing and means i need to start over?
Old Oct 24, 2012 | 06:31 PM
TORN's Avatar
Car: 88 IROC-Z
700 seem high to me. Tech on front page says to adjust to 450.
Take the paper clip and open it up and form it into a big "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' pins.
Turn on the ignition, but don't start the engine. Wait 30 seconds. Now, go remove the connector from the IAC.
Start engine. You are now going to adjust "minimum air". There is a Torx screw on the side of the throttle body. This is what needs to be turned to adjust minimum air, or more commonly known as "idle speed". It comes from the factory with a protective metal cap over it. If the cap is still there, use a small punch to knock it out. Set the idle speed to 450 rpm, rotating the Torx screw clockwise to raise rpm, and counter-clockwise to lower rpm. Once the idle rpm is set, turn off the engine.
Re-connect the connector onto the IAC. Start engine. Idle speed is now once again governed by the ECM, but your idle should be smooth and steady, approximately 600 rpm in Drive (for unmodified cars).
If you set an SES light by having the IAC disconnected, then after shutting down the engine disconnect the negative battery terminal. Wait 5 minutes. This will clear the ECM of all trouble codes. Re-connect the battery and drive the car for 20 minutes to allow the ECM to relearn your driving style.
Old Oct 24, 2012 | 06:48 PM
Engine: Lb9
Transmission: M20
Old Oct 24, 2012 | 07:10 PM
subroc's Avatar
Engine: 355 TPI
Guys i have a cam i cant get the car to idle that low. It will idle for a little while but then die. I cant get the idle to pick up in the tune either using the one or two idle tables.
Old Oct 25, 2012 | 11:49 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
This was a post of some testing I did on a bench with an SD system.
The parameters may translate to what you are using.
It was with a startup "flare" problem but I did find how to make the RPM come down quicker at a stop.
Take a look.
https://www.thirdgen.org/forums/diy-...ont-reset.html
Jp
Old Nov 16, 2012 | 06:16 PM
subroc's Avatar
Engine: 355 TPI
Ok im back again. I just got done swapping a Arizona speed and marine ported 52mm throttle body on and resting my idle and TPS (this time going by the books at around 450...had to guess that since my engine would not run under 500rpms). Idle is nice and smooth but i STILL have a hanging idle when i come to a stop. Ive looked around at thread after thread about idle follower and IAC anything and most of them have to do with SD. Im still running a maf and tuning with a a 6e def. Anyone have any experience as to what in the tune i need to change to make this thing stop doing that?
Oh and it doesnt do it in closed loop. Only in open loop when warmed up.
Old Nov 20, 2012 | 02:58 PM
subroc's Avatar
Engine: 355 TPI
bump anyone?
Old Nov 20, 2012 | 03:21 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Originally Posted by subroc
bump anyone?
try lowering the idle limiter values
Old Nov 20, 2012 | 04:21 PM
TORN's Avatar
Car: 88 IROC-Z
Did you switch everything over to the APYP .bin yet? If you are running ARAP its looking for the torque converter that is no longer there.
Old Nov 20, 2012 | 04:26 PM
subroc's Avatar
Engine: 355 TPI
Wont switching over to that screw up all my tuning up to now? My car is tuned on the ARAP right now and id rather not loose all of that and start over.
Old Nov 20, 2012 | 04:27 PM
subroc's Avatar
Engine: 355 TPI
I didnt see that anywhere in tunerpro but i will look again when i get a chance.
Old Nov 20, 2012 | 04:31 PM
TORN's Avatar
Car: 88 IROC-Z
Well yes and no there are settings deep in the .bin that are setup for a manual car that can't be changed by tunerpro. That is what I read on here and is why I would suggest you do the same. Roll your spark tables over into the APYP .bin and see how far off it is. the ARAP and APYP was made for the same year car only difference was trans.
Old Nov 21, 2012 | 11:23 AM
Ronny's Avatar
Are their filters in TP for your def file? Filter will time out the event to end earlier or later. The event being throttle follower. smaller filter-event lasts longer.
Old Nov 21, 2012 | 02:59 PM
subroc's Avatar
Engine: 355 TPI
I have no clue about filters or not. The big thing is i did a search through tunerpro and could not find anything about throttle or throttle follower at all. Is it named something else or am i looking in the wrong spot?
Old Nov 21, 2012 | 03:48 PM
Ronny's Avatar
IAC-throttle follower ?
AE-throttle follower ?
Old Nov 21, 2012 | 04:20 PM
subroc's Avatar
Engine: 355 TPI
Nope nothing on either of those. I searched for throttle got nothing....searched follower got nothing. I looked at all the IAC settings and dont really know what to change so i didnt mess with them yet.
Old Nov 22, 2012 | 08:56 AM
EagleMark's Avatar
You've had lots of good advice here but keep looking for an IAC parameter to change, many times you can't tune out a mechanical issue.
Like why did your car idle lower with new throttle body and not old one?
But I think your biggest issue is the Auto bin. If you open up 2 TunerPro you can move your tuned stuff into a Manual bin easily. There are big changes in IAC logic from Auto to Manual. Just move tuned stuff and leave other stuff alone, you can change to much.
The way you did min Air Adjust by the book would be fine if your idle is set by the book. But you said it idles higher RPM because of cam. So take that idle, say 800 RPM and set min air 100 RPM below that. Point is to give some work to IAC but not all work. This adjustment has to be done totally warmed up and even driven to be accurate.
You car was an Auto, now Manual, the P/N wire must be disconnected. I know you said it was but this issue is clearly caused by this in other cases.
Data log when it's happening! Compare RPM and MPH to settings in bin. Is your VSS working properly?
One parameter I think could help if it is in your mask is "IAC - Position vs Temp" cutting these in half is usually where I start with idle issues like this... when all other things above are in order.
HTH!
Old Nov 22, 2012 | 08:15 PM
subroc's Avatar
Engine: 355 TPI
HTH!
I guess i should have been more clear. The 52mm throttle body didnt change anything. It behaved the same with both as far as hanging idle.
My big question is...how can i easily switch everything over to a manual bin? Im a bit PC stupid (use a mac mostly) so im not exactly sure of the logistics of it. From the sound of it that could very well be my problem.
Old Nov 22, 2012 | 09:40 PM
EagleMark's Avatar
Open TunerPro with your tuned bin file and XDF. Parameter Tree and choose Parameter Ordered List, now you will have all parameters open.
Go to Tools, Custom Tools and New TunerPro Instance.
In the second TunerPro load your new stock bin and xdf.
Right click on the Parameter you want to copy from tuned bin and choose Copy XDF Parameter to Clip board, right click on new bin and paste it in under old one and delete old one. One by one of what you want. Should be very specific like fueling, spark and important changes, not all of them! Manual and Auto have a lot of different settings. Then test it, tune, rinse and repeat!
Old Nov 23, 2012 | 08:16 AM
subroc's Avatar
Engine: 355 TPI
Thanks! I will give that a try once i get home.
Terrell351
Jun 13, 2021 01:13 PM
jklein337
Sep 19, 2018 06:23 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
