Gear change in Eprom?
Old Nov 6, 2012 | 06:35 AM
polymer52's Avatar
Im using Tunerpro and I can't seem to find where to change the gear ratio.
Is it programmed in the eprom or is it ignored on TPI?
Old Nov 6, 2012 | 02:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Gear change in Eprom?
There isn't a 'gear ratio' per say in the calibration. If the rear gear ratio is changed this will affect the N/V ratio values when using a stick shift. And may require a change to the TCC lockup tables with an automatic.
As for the speedometer and the ECM's MPH readings, that is done via the drive & driven gears for the VSS or cable in the transmission.
RBob.
jklein337
Sep 19, 2018 06:23 PM
Warlocksirix
Sep 3, 2015 12:26 PM
jbd1969
Aug 17, 2015 07:06 PM
the_nikfive
Aug 11, 2015 02:46 AM
