165 to 730 ecm and prom
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
Currently running a custom burn on my 29c256 prom in my 165 ecm. If I convert to SD using the 730 ecm, using TunerproRT can I simply read my current bin, save it and burn that back to the 29c256 chip using the new mask? Can I still use the PP2 to burn the prom? Last question..Can I convert to this ecm with aujp and not be supercharged yet? Will it run? Looks to be like night and day between the 2 ecm's and bin's..Thanks...
Car: check
Engine: check
Transmission: check
Re: 165 to 730 ecm and prom
You can use the PP2 for the '7730 ECM PROM. It uses the '256 kb chip, but the whole thing not just half.
Yes, it will run, but will require tuning.
Most likely the only part of the '7165 tune that you can use are the SA tables. Note that AUJP has VATs enabled, so need to clear the flag for it.
RBob.
RBob.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the 165 maf memcal will work in the 730 but you have no knock filter. You can use the esc module from the maf and input to B8 and cal 29 4k to ground.
