Help with tunerpro rt 5
Old Mar 20, 2013 | 11:10 AM
plainwhitedog's Avatar
i am struggling with this program. is there any good videos teaching how to use it? also i cant find the bin files or def files xds or any other files. nor do i understand the difference or uses. any help would be great. i would like to practice datalogging first. then chip tuning and burning. i have the cable from moates and the program from tunepro.net
Old Mar 20, 2013 | 11:11 AM
Re: Help with tunerpro rt 5
my camaro is 1991 z28 350 TPI 5.7 what codes are associated for this car?
Old Mar 20, 2013 | 11:15 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The down loads states the difference in the extension files. You will need to download the $8d (.xdf for bin definitions and .adx for datastream definitions).
Old Mar 20, 2013 | 12:10 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Does this help?
https://www.google.com/search?q=tunerpro+video
Old Mar 20, 2013 | 12:22 PM
I downloaded those how do you load them in tunerpro it doesn't recognize them maybe I download them wrong not quite sure
Old Mar 20, 2013 | 12:24 PM
Engine: Lb9
Transmission: M20
Do you mean there hidden when you try to select a path when loading the adx ? If so place them into a new folder or location.
Old Mar 20, 2013 | 12:40 PM
i put them in the same folder as tunerpro like it says and they do no appear when i hit load xdf
Old Mar 20, 2013 | 12:55 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
How did you download them?
It seems that come browsers download then as .txt files instead of the proper .xdf and .adx formats.
Old Mar 20, 2013 | 12:57 PM
Engine: Lb9
Transmission: M20
why are you loading the xdf ? Are you editing your .bin ?
Like I said above put the files in a different location then select the path.
Old Mar 20, 2013 | 01:01 PM
which one is the bin. im sorry im trying to understand all of this
Old Mar 20, 2013 | 01:18 PM
Engine: Lb9
Transmission: M20
You need to read through the stickies on basic tuning how to get started. The .bin is a binary file a read off your eprom. Unless you have a chip reader/burner don't worry about it. Do as six_shooter suggested if you double click on the adx for download you may download a text. Right click on the adx and chooses save as. I have had the files show in a folder but are invisible when you choose load definition in tuner pro. For that reason to get you going just put it to your desk top for now.
Old Mar 21, 2013 | 11:09 AM
EagleMark's Avatar
Yup, if your getting them off the TunerPro website don't click, right click and Save As, don't save a s text file. Or just get the files here, TunerPro website files have not been updated in years, we keep updated versions:
http://www.gearhead-efi.com/Fuel-Inj...Information-8D
This write-up helps clear up a lot of the beginning file extension issues.
http://www.gearhead-efi.com/Fuel-Inj...-a-must-read!-)
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
