$32B Flow rate issue
Old May 1, 2013 | 11:34 AM
MrWillys's Avatar
In the $32B program there's a Injector flow rate that I've changed to 42 lbs. Should the Display Injector Flowrate table also be modified to reflect this change using the following formula:
42 / 5.85 = 7.18 Gallons per hour? Factory programming being 3.81 GPH.
Old May 1, 2013 | 02:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $32B Flow rate issue
Not unless you have the driver information center (DIC) installed in the ******.
RBob.
Old May 1, 2013 | 03:07 PM
MrWillys's Avatar
RBob.
This is in a 85 Vette converted to a 165 with a 434 running 10.94. I've changed the injector flowrate caveat, but was wondering what effect this Display injector table had. I've read that in 85 under the 6870 you would use injector lb rated divided by 5.85 for this value?
Old May 1, 2013 | 06:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm you're tech support?
RBob.
Old May 1, 2013 | 06:52 PM
MrWillys's Avatar
Thanks!
Are there any reasonable people that may know this answer?
Old May 1, 2013 | 07:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by MrWillys
Thanks!
Why? Are you hoping that they may be your tech support? Scott Hansen...
This is a DIY board, one for the folks doing their own tuning...
Thread closed as your intents are not DIY.
RBob.
customblackbird
Aug 15, 2021 10:16 PM
formula_novice
Sep 5, 2015 03:58 AM
sailtexas186548
Aug 26, 2015 03:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
tmellott89
Aug 16, 2015 02:58 PM
