TF % Gain
Old Jun 29, 2013 | 04:21 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
TF % Gain
RBob,
I have read some of your comments before that you like to set TF Gain% so as to get MAX IAC steps at ~ 100% TPS. I have my MAX IACs set at 175 and a TF% Gain at 70%. So I decided to datalog this and see what IACs were at TPS =
99+%. IACs hardly moved at somewhere around 23 steps. I am obviously misunderstanding how you are going about this. Would you clarify further?
Old Jun 29, 2013 | 05:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TF % Gain
It is likely something in the code, I'm not running $D0. If there is a max TF steps parameter be sure it too is set high.
RBob.
Old Jun 29, 2013 | 05:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TF % Gain
Check this table @ L87D9 (or @ L87DC, 3 byte offset?):
Throttle Follower vs MPH * 2
That may be a maximum allowed TF versus MPH.
RBob.
Old Jun 29, 2013 | 09:48 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Re: TF % Gain
RBob.
Exactly RBob. When I read your first post, I thought of that table and saw that the max TF at the MPH was that #. I need to get above 92mph to get to the 175 IAC counts. I did notice that dropping the gain % did make the accelerator more responsive. Right now I have it set at 70%. Not sure I want it more sensitive but there's only one way to find out
Old Jun 29, 2013 | 10:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TF % Gain
Too much gain makes TF sensitive to throttle input. I reduce the gain to make it more linear.
TF also affects HC emissions on a lift. More so on a wet flow system such as TBI.
RBob.
Old Jun 29, 2013 | 10:58 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Re: TF % Gain
RBob.
RBob,
Interesting because the stock calibration uses a 99% TFGain. I would agree w you that my setting at 70% has the pedal feel much more linear to the desired output based on the input.
Old Jun 30, 2013 | 08:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TF % Gain
Originally Posted by Dominic Sorresso
RBob,
But the amount of TF steps is limited at low speeds. 30 steps at 0 MPH (prevent stalling when taking off). Then 5 steps from 8 - 48 MPH. Then 25 steps from there to 88 MPH. At which time the maximum steps really goes up (125 - 175).
Yep-er', as the engine performance goes up, it is more responsive to throttle. Taming down the IAC TF helps in this regard.
Another one that can drive you batty is stall saver (TBI only, does not apply to $D0, $8D, $32 or $6E). I had the trip point too high at one time. So nearly every time I let out the clutch the RPMs would dip, hit the stall saver, and the ECM yanked the IAC open to prevent it from stalling.
The issue was that once the RPM recovered the stall saver steps were decayed out and the car stopped accelerating. I then had to depress the go-pedal further to continue on.
RBob.
Old Jun 30, 2013 | 08:40 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Re: TF % Gain
RBob,
In fact, not only did I lower the TF Gain % but I also dropped the Max IAC v MPH
COUNTS until higher speeds. As for the Stall Saver, I took your advice and dropped the disable down to 0 and now it doesn't stall when free-wheeling in neutral down to a stop.
Even though its SPFI and not TBI, you still want as much air velocity going through the throttle body as possible and not bypassing thru the IAC.
Old Jun 30, 2013 | 12:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TF % Gain
RBob,
The stall saver in the $D0, $8D, $32 or $6E masks is a bit different. No IAC action, they just assert the EST/BYPASS line to force the ICM to base timing. It may work for stock engines, but it sure doesn't work on modified engines...
RBob.
Old Jun 30, 2013 | 06:20 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Re: TF % Gain
"But the amount of TF steps is limited at low speeds. 30 steps at 0 MPH (prevent stalling when taking off). Then 5 steps from 8 - 48 MPH. Then 25 steps from there to 88 MPH. At which time the maximum steps really goes up (125 - 175)."
RBob,
So 88mph is when things really begin to happen? Sometimes the LT-5 feels as if it has a
Flux Capacitor! . LOL!
Old Jun 30, 2013 | 07:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TF % Gain
To me, it would seem that GM wants the car to be drive-able, without driving into the rear end of the car in front of them. My Firebird is still somewhat in that category. I always pause before taking off.
RBob.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
