Stalling problem difficulty to trace.
Old Sep 5, 2013 | 01:01 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
87 Camaro 2.8L, no EGR, V6, 165 ECM $6E, T-bird MAF, Ford Disc Injectors (stock flow rate), new oxygen sensor, new CTS, CS 144 alternator, no vacuum leaks.
Car stalls at times durning its initial run in the morning, and while driving a few times about a mile or two out. Then for the rest of the day it does not stall. It only happens in the morning. Attached is a log, I stall 3 times. Once down the road, then again when I get it to run again, and finally again a mile or so away at a stop light.
The car wont start after it has stalled, I have to for some reason move the MAF connector for it to fire. I have re-wired and check the MAF connector connections, and have tested the output. I also have tried two different MAF sensors. It doesn't happen when it has been driven past that two mile point for that specific day.
Thanks, any help is appreciated.
File Type: zip
Old Sep 5, 2013 | 03:44 PM
Axle/Gears: 10 Bolt
Re: Stalling problem difficulty to trace.
Anyone?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
