165 ecm a8 signal problem to aldl.
Old Sep 6, 2013 | 10:27 AM
anthonyjmarshal's Avatar
Car: 85 Camaro Iroc-z
Engine: 355 Tpi Holley Stealth Ram Vortec
Transmission: 5 Speed Manual T5 WC
Axle/Gears: 3.42 eaton posi lock 28 spline
I am having a problem with my a8 signal wire going to the aldl. For some reason it is sending 12volts when key is on. I believe it is suppose to be between 2-5 volts. Does anyone have an idea what causes this problem or how to fix it?
The check engine light will flash codes still but will not send data to a scanner. Keeps saying no signal or no activity. I have tried with and without 10k ohm resistor. I did swap from the old 870 85 ecm to the 165 ecm although everything runs great except for that signal issue.
Any help is appreciated. Thanks in advance.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Elephantismo
Feb 13, 2019 12:51 AM
thunder57
Nov 7, 2015 02:28 PM
customblackbird
Oct 1, 2015 04:30 PM
