HSR tuning questions
Old Nov 4, 2013 | 08:51 PM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
Hey friends, just wondering what the hsr intake likes for tuning....check my sig for Mt can specs...but I think I read somewhere that the intake like full timing in by 3500 rpm...mine is at 30 degrees by 6400 which is the top of the table. Keep in mind I have cast heads so it won't be as radical as if I had aluminum heads.also if anyone has any tips for tuning this intake id greatly appreciate it...this wad my first year messing around with this stuff so I still have LOTS to learn.
Cheers
Old Nov 4, 2013 | 09:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: HSR tuning questions
what compression? with vortecs thats not a bad place to be but you can maybe try 32-34 to see what happens else stay where your at. Peak torque rpm you may want to try 2 deg less than peak hp rpm timing and see what that gives you
Old Nov 4, 2013 | 10:50 PM
88Trans-am's Avatar
Compression is stock for a 96' chev motor...I have not even checked that to be honest...I usually shift around 5500 ish rpm..
MustangBeater20
Oct 29, 2022 09:20 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
355tpipickup
Aug 13, 2015 07:35 AM
