Changing injectors, have egr cs delete recommend?
Old Dec 15, 2013 | 04:44 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Going to swap in new injectors while under there I figure I will do
Cold start delete.
I bought egr delete too
And will remove AIR pump
So I here the reasons for keeping egr but this is not. Dd
At all. The solenoid was disconnected from PO and probably broken
So is it ok to delete and I have moates so I can tune
I will set enable to 255 for egr to disable that should be all?
Cold start I will plug with hawks kit. Do I need to switch to $6e or can I stay with $32b for now? What in $32b do I need to increase for delete
Air delete is simple I set air mv scalar to 0
Any tips links feedback on similar rides
Mine is 88 lb9 auto
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
