Initial suggestions on where to tune for this log?
Old Feb 21, 2014 | 09:01 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
I have a 355 TPI in a 90 firebird. I got an starting tune from LT1 PCM tuning but that a a while back, so I ran out of tuning help there.
The car idles OK until it goes into closed loop and then it starts surging or oscillating from nearly dying to about 1000rpm.
The engine is as follows:
ported Patriot iron vortecs
10.5:1
comp cams CC305 220/230 114
1.6 rollers
Also I can see the engine go lean when I rev in neutral. You can see that in the attached log file also. Do I have move volumetric eff values up?
I appreciate anyone downloading the log and taking a look.
File Type: zip
Old Mar 7, 2014 | 11:36 PM
armos's Avatar
Re: Initial suggestions on where to tune for this log?
I don't normally use TunerPro RT, and I've never tried looking at an .XDL log file in that program, so I'm probably just doing something wrong.
But when I tried to play that log it showed coolant and manifold air temps of -40 (open circuit), and lots of error codes. I might just be doing something wrong on my end though, I'm used to .txt logs.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
earlpote
Sep 12, 2015 11:55 AM
WickedBowtie
Sep 11, 2015 11:24 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
