Am looking for GM-generated ignition map for unmodified L98 using a MAP sensor
Old Aug 5, 2014 | 07:40 PM
WorkInProgress's Avatar
Hi All,
I am looking for a copy of the factory ignition map programmed into the factory ECM used on a MAP-based L98(aluminum head) + 700R4.
I have a 1989 L98 + 700R4 in my 1966 ChevyII. I converted the MAF-based L98 to MegaSquirt(MAP/speed-density) and have it running reasonably well.
I am looking for a GM-supplied ignition map aka spark table so I will have a known good baseline from which to start tuning. I need to reproduce the ignition behavior of the stock 1227165 ECM.
Please let me know if you have any information on where I might be able to find this file. Also, it would be helpful to know the file name I'm looking for.
Thanks in advance.
Ron
Old Aug 5, 2014 | 08:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Am looking for GM-generated ignition map for unmodified L98 using a MAP sensor
Look (goog) for the ANHT $8D BIN. That is a '90 y-body 700R4 calibration.
RBob.
Old Aug 8, 2014 | 09:23 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by WorkInProgress
Hi All,
Thanks in advance.
Ron
Keep in mind that the factory GM timing map is handicapped for emissions reasons and that your 1966 is nowhere near as aerodynamic as a C4 Corvette. Also keep in mind most of those C4 cars ran ring and pinons as steep as 2.59:1. With the common gearing in those older cars you will be turning more RPM and pushing more load. The timing map used for a Corvette may be totally unsuitable for your car. The ECM you need to use is the 7730 as an underhood derivative 727 was used in the 90-91 speed density "MAP" aluminum head corvettes.
Old Aug 8, 2014 | 09:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If its an iron head fbody L98 do not use the vette tables.
I think a search for AUJP should do it. Any 91-92 L98 fbody bin should be a good start
Old Aug 28, 2014 | 12:19 PM
RBob.
Hi RBob -
Thank-you for the reference / info. I've loaded it into my MegaSquirt DIYPNP D56 system. The data logs don't show any signs of detonation and performance is noticeably better.
specs for my 1966 ChevyII coupe: rear axle gears = 3.55, rear tire = 255-60R15, vehicle weight (no driver, half tank gas, no spare tire) = 2940 lbs, aluminum headed unmodified L98 + 700R4.
Thanks again for your help; it is much appreciated.
Ron R
Old Aug 28, 2014 | 12:23 PM
Hi Fast355 , Orr89RocZ -
Thx for the info and recommendations. I am trying out RBob's recommendation and testing to date indicates that it will work for me.
Ron
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
