Chip memory range
Old Aug 11, 2014 | 10:45 AM
305_firebird's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: L98 TPI 350 Originally 305 TBI car
Chip memory range
I'm trying to burn a new .bin onto an EEPROM I got from Moates. I have a 16KB 88 TPI EPROM. I read somewhere that you can just change the memory addresses to burn only the last 16 kb of the chip and that it will work. Anyone know the HEX ranges to burn to?
Old Aug 12, 2014 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Chip memory range
In the help or support section on Craig's site there is a chart for this. It may be in the help for the Burn1.
RBob.
Old Aug 12, 2014 | 08:47 AM
Thank you. For 27C128 EPROMs, the actual .bin data needs to be at the end it appears. From address 004000 to end (007FFF) when using the 27SF512 EEPROM.
Old Aug 12, 2014 | 11:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
http://support.moates.net/programmin...using-offsets/
Code:
File Size         Chip        Buffer Start -> End   Chip Start -> End
16k (16384)       27SF512     000000 -> 003FFF      00C000 -> 00FFFF
As you can see, the buffer (or file content) will be placed at the ‘end’ of the chip.
RBob.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Vintageracer
Sep 24, 2017 12:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
