initial timing-$8D, 730
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
This has probably been explained many times before, so I apologize for taking everyone's time again. I know I have to enter the initial timing in the bin file ( in my case 12 degrees) When I look at the main spark advance tables, are the values there in addition to the initial in the distributor? If at 2400, and 80kpa, the value is 32, does that mean the actual amount of advance is 12, + 32, = 44 degrees advance? If this is so, why does the ecm need to know what the initial timing value is?
Car: 1983 G20 Chevy
Transmission: 4L60
Re: initial timing-$8D, 730
Getting more advanced the distributor latency settings must match the ignition control module in use and even the factory have some timing variation to them. The 048 module retards the timing above 3,200 rpm, while the 369 advances.
maticulus
Aug 19, 2012 07:26 AM
91L98Z28
Feb 18, 2005 12:05 AM
