7730 : MAP vs. Power Brake Booster?
Old Nov 22, 2014 | 08:58 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
Presently tuning (1st time) a SD based 7730.
In searching through the posts, I found a reference to using a vacuum restrictor in-line with the hose that goes to the Power Brake Booster.
I presently do not have this installed in my car.
Is an in-line restrictor required?
Any suggested vendor or part number?
Best Regards,
Bruce
Old Nov 22, 2014 | 01:14 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Re: 7730 : MAP vs. Power Brake Booster?
Hi Bruce
i think you mean a check valve, when letting of the gas pedal, MAP goes down and evacuate the brake booster.....when you stomp the gas again the check valve will hold the vacuum in the booster for a "vacuum reserve"
just to be sure to mount it in the correct direction...air must flow from booster to engine...
you can use one of these:
http://www.ebay.com/itm/POWER-BRAKE-...-/191248786132
search for "brake booster check valve" or similar...
Old Nov 26, 2014 | 10:28 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thank You!
Vintageracer
Jan 10, 2020 05:33 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
