How to get ads file to tuner pro?
Subscribe
Feb 27, 2016 | 12:57 PM
What's up guys I'm totally new to tuner pro...I got my computer to recognize the cable but can't get it to connect to my ecm....how do I download the ads cable from moates so I can data logv the car. ? Any help would be appreciated. Thanks.
Reply 0
Feb 27, 2016 | 02:41 PM
Re: How to get ads file to tuner pro?
Once you download and install the moates drivers for USB. I think you need to select a com port first unless APU1. My computer and tunerpro connected to it right away. Also you have your correct .bin .xdf and .ads files for your vehicle?
Reply 0
Feb 27, 2016 | 02:47 PM
I downloaded turner pro...and that's all I've done I connected the aldl cable and tested it. It said it picked up the aldl cable...I have not put any files in it though...that's what I'm trying to do.
Reply 0
Feb 27, 2016 | 02:58 PM
Download your files from tunerpro website. You can't do anything without your correct files for your vehicle. Then once downloaded. In tunerpro go to the top and load in your files. Where it says acquisition click the drop menu and click load and should let you search your adx on PC then load. Still think you might need to download the USB drivers.
Reply 0
Feb 27, 2016 | 02:59 PM
In the menu system you have options to select a bin file, a Xdf file and an ads/adx file. Just check all menus.
Reply 0
Feb 27, 2016 | 03:55 PM
How do I download the USB drivers? Sorry for all the questions...I'm like so confused over all this
Reply 0
Feb 27, 2016 | 04:40 PM
Moates website has them.
Reply 0
Feb 27, 2016 | 04:50 PM
Does this mean it got the ads?
Reply 0
Feb 27, 2016 | 05:22 PM
Looks like it, if it's correct for your vehicle. 90-92 tpi camaro.
Reply 0
Feb 27, 2016 | 05:24 PM
still cant get it to connect? maybe i need a xdf file?
Reply 0
Feb 28, 2016 | 01:11 PM
8 got I assume the xdf file in there I got the little things on the side to pop up the flags and scales and stuff....I just can't get it to connect to my ecm for some reason....I verified the cable is being detected and everything checks out...when I go to connect noting happens?
Reply 0
Feb 28, 2016 | 05:54 PM
Finally got it to connect today....all I can view is the item list which tells me basically what the car is doing..I got a red number that red target afr and it's like at 14.7 I'm assuming I need to put the empty chip in they'd to start changing stuff on it?
Reply 0
Feb 28, 2016 | 07:38 PM
Target AFR won't really change unless under wot. Your blm and ints are what you want to look at for fuel trim. 128/128 being stoich higher the number (140) would be lean. Lower number (100) would be rich. Tune to hover around 128/128,under all load conditions.
Reply 0
Feb 28, 2016 | 07:45 PM
Go to the prom tuning guide book and start reading the stickies in there. Especially $8d stickys. Lots of knowledge from many men, even many moons ago.
Reply 0
Subscribe
